15 years agotse_mac code PROBLEM
hi:
I encounter a problem about a piece of code,as follows: ------------------------------------------------ dat = IORD_ALTERA_TSEMAC_CMD_CONFIG(TSE_MAC_BASE); if( (dat & 0x03) != 0 ) printf("WARN: RX/TX not disabled after reset... missing PHY clock? CMD_CONFIG=0x%08x\n", dat); else {printf("OK,CMD_CONFIG\n"); // printf("Hello from Nios II!\n"); } printf("Hello from Nios II!\n"); -----in NiosII console,it can print :OK,CMD_CONFIG but,can not print "Hello from Nios II!",seems that the code is not running down. I suspect if maybe the reason of timer,so I add a timer(10us)in SOPC,and set the "sys_clk_timer" and "timerstamp_timer" in NiosII BSP,but after running the code ,there is nothing to print in NIOSII console,if I add none to "sys_clk_timer" and "timerstamp_timer",then it can only print "OK,CMD_CONFIG",and cannot print "Hello from Nios II!" . I donnot understand the reason ,and suspect that what is missed to set in quartusII or niosII SBT.No RepliesBe the first to reply
