18 years agoTSE MAC and Marvell 88E1111
I'm having trouble to bring up the TSE MAC to Ethernet interface on the Stratix II GX PCIe board. I was able to instantiate a triple speed Ethernet MAC and build logic around it. The loopback at the ...
16 years ago --- Quote Start --- Hi Foreshadow, First of all look at your comand config register = 0x00000000 it can't be so in full duplex and 100 Mbit. Then the main error - no PHY, maybe there are some errors with physical connection of PHY. have a look in closed topics to this, there some pictures of pinouts, it should help you. --- Quote End --- Thank you for your answer. I have found the solution here: http://www.alteraforum.com/forum/showthread.php?p=86569 И.. Кстати, из Ваших постов подчерпнул несколько весьма полезных замечаний, которые удалось применить в своем дизайне.. Спасибо))) А проблема была в том, что именно на этой отладочной плате (3sl150) неудачно подключен чип Marvell - нужно перезагружать вручную...
