pknbanzai's avatar
pknbanzai
2 years ago
tse ethernet HW transmit issue
Greetings,
I have a tse ethernet block implemented in a design, and can only get a 1-word and 2-word read to transmit to the computer. I'm using Wireshark to capture packets.
I also have the ethernet block set up to generate the CRC.
Started with an EVP example design on Intel Startix 10 AX Development Board, modified the AVMM user interface to be 8-bits (was 32-bits). Added our own interface to the tse blk. I can observe packets getting sent to the tse block using Signal Tap.
So far, I have not been successful in getting more than 2-word reads to transmit to the computer.
I've been working this issue for a week, and am at a point for some help.
Thank you.
Peter Ni**bleep**a
310-812-7175
peter.ni**bleep**[email protected]
  • ZiYing_Intel's avatar
    ZiYing_Intel
    We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum case, did not reach us as intended. As a result, we have a backlog of cases that we are currently working through.
    Please be assured that we are doing everything we can to resolve this as quickly as possible. This will take some time, and we appreciate your patience and understanding during this period of time. Your case will be attended by AE soonest possible.
    Thank you again for your patience and understanding, and we are committed to provide you with the best possible support.
    zying
    ZiYing_Intel
    We need below information to check
    • TSE IP register setting and status (before/after sending packet from user side)
    • SignalTap waveform when customer is sending packets at the TSE IP input/output ports
    • How user change AVMM I/F bus width from 32bits to 8bits
    zying
    ZiYing_Intel
    Is there any update from your side?
    zying
    ZiYing_Intel
    zying
    ZiYing_Intel
    Since no hear any feedback from you, I am now close the case. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
    zying
    • pknbanzai's avatar
      pknbanzai
      Hi Zying,
      My apologies for not responding.
      Yes, this ticket can be closed. The issue has been resolved.
      Peter
