16 years agoTSE connection problem
Hi all, I got a problem when I tried to connect the TSE MAC to the PHY, some thread said that the enet_gtx_clk should be connected to a 25MHz clock along with the tx_clk_to_the_tse_mac, but my...
16 years agoThe connection to the clock source is already done in the nios2_linux_3c120_125mhz_top file.
Why don't you use nios2_linux_3c120_125mhz_top as your top level file, instead of putting it in a block and reconnect all the pins?
