8 years agoTrouble with Arria10 dev kit FPGA EMIF
I’m having trouble implementing an FPGA DDR4 EMIF on the Altera Arria10 Dev board. I can generate the emif example design (with the traffic generator etc) and that works fine. But when I try to i...
8 years agoI am on a similar path as you. I am using the A10 SoC Devkit trying to get a handle on DDR4 use. i am using Quartus v17.0.2 and when I create the example design it runs fine and I can see sucessful reports in the EMIF toolkit, but in my program using the same DDR4 QSYS file I get no memory function. I am getting good timing closure (using the reference recommendations), but if I use SignalTap I can see that the emif_ready line never changes when I write or read (and of course my read result is always zeros).
Any chance you can pass along a source_top file I can scan through as I am exhausting the reasonable project rebuild efforts here. Thanks,srinivasan
5 years agoHi,
can u please share your ddr4 example design project folder..
