Triple speed ethernet and Marvell Phy on Stratix III
Hi..
Need help here!! I've been struggling for a couple weeks. I have a stratix III board with a on-board Marvell PHY. I just tried to make a triple speed ethernet working on MII mode (10/100 is good enough, i don't need high speed.) So i just take CycloneIII's example (from its development kit) as a reference for the SOPC and follow the manual of TSE. Also I add a redundunt reset circuitry for this enet_reset since there is a certain issue on this kind of setup which i got from this forum. However, it never worked. Symton is as follows.. BTW i use Simple socket server on NIOSII and Quartus8.0 SOPC. PHY can receiver packet (it seemed.. because i can see RX LED is blinking when i tried 'ping').. but no Tx ( i never see TX LED blinking.) Also i set a break point on SGDMA rx int.. it never asserted. So i guessed TSE_MAC never receives data from PHY. I know there should be some tools which could verify something for me.. Sorry.. I'm a newbid in Altera FPGA. So if you think there is anything i should check or modify.. Please let me know. Of course, if you make it work before, could you please share that with me? Thanks.29 Replies
Alright.. here you go!!# **************************************************************# Create Clock# **************************************************************
create_clock -period 20 -name clkin_50 [get_ports {clkin_50}]# create_clock -period 8 -name clkin_125 [get_ports {clkin_125}] create_clock -period 100 -name tck [get_ports {altera_reserved_tck}] create_clock -period 8 -name virtual_enet_rx_clk_125M create_clock -period 40 -name virtual_enet_rx_clk_25M create_clock -period 400 -name virtual_enet_rx_clk_2M5 create_clock -period 8 -name enet_rx_clk_125M [get_ports {enet_rx_clk}] create_clock -period 40 -name enet_rx_clk_25M [get_ports {enet_rx_clk}] -add create_clock -period 400 -name enet_rx_clk_2M5 [get_ports {enet_rx_clk}] -add create_clock -period 40 -name enet_tx_clk_25M [get_ports {enet_tx_clk}] create_clock -period 400 -name enet_tx_clk_2M5 [get_ports {enet_tx_clk}] -add# **************************************************************# Create Generated Clock# ************************************************************** create_generated_clock -name enet_gtx_clk -source [get_pins {this_stratixIII_3sl150_dev_niosII_standard_sopc|the_sys_pll|the_pll|altpll_component|auto_generated|pll1|clk[1]}] [get_ports {enet_gtx_clk}]# **************************************************************# Set Clock Latency# ************************************************************** # **************************************************************# Set Clock Uncertainty# ************************************************************** # **************************************************************# Set Input Delay# ************************************************************** set_input_delay -clock { virtual_enet_rx_clk_125M } -min 0 [get_ports {enet_rx_col enet_rx_crs enet_rx_d[0] enet_rx_d[1] enet_rx_d[2] enet_rx_d[3] enet_rx_d[4] enet_rx_d[5] enet_rx_d[6] enet_rx_d[7] enet_rx_dv enet_rx_er}] set_input_delay -clock { virtual_enet_rx_clk_125M } -max -add_delay 6 [get_ports {enet_rx_col enet_rx_crs enet_rx_d[0] enet_rx_d[1] enet_rx_d[2] enet_rx_d[3] enet_rx_d[4] enet_rx_d[5] enet_rx_d[6] enet_rx_d[7] enet_rx_dv enet_rx_er}] set_input_delay -clock { virtual_enet_rx_clk_25M } -min -add_delay 9.5 [get_ports {enet_rx_col enet_rx_crs enet_rx_d[0] enet_rx_d[1] enet_rx_d[2] enet_rx_d[3] enet_rx_d[4] enet_rx_d[5] enet_rx_d[6] enet_rx_d[7] enet_rx_dv enet_rx_er}] set_input_delay -clock { virtual_enet_rx_clk_25M } -max -add_delay 30.5 [get_ports {enet_rx_col enet_rx_crs enet_rx_d[0] enet_rx_d[1] enet_rx_d[2] enet_rx_d[3] enet_rx_d[4] enet_rx_d[5] enet_rx_d[6] enet_rx_d[7] enet_rx_dv enet_rx_er}] set_input_delay -clock { virtual_enet_rx_clk_2M5 } -min -add_delay 9.5 [get_ports {enet_rx_col enet_rx_crs enet_rx_d[0] enet_rx_d[1] enet_rx_d[2] enet_rx_d[3] enet_rx_d[4] enet_rx_d[5] enet_rx_d[6] enet_rx_d[7] enet_rx_dv enet_rx_er}] set_input_delay -clock { virtual_enet_rx_clk_2M5 } -max -add_delay 390.5 [get_ports {enet_rx_col enet_rx_crs enet_rx_d[0] enet_rx_d[1] enet_rx_d[2] enet_rx_d[3] enet_rx_d[4] enet_rx_d[5] enet_rx_d[6] enet_rx_d[7] enet_rx_dv enet_rx_er}] # **************************************************************# Set Output Delay# ************************************************************** set_output_delay -clock { enet_gtx_clk } -min -0.5 [get_ports {enet_tx_d[0] enet_tx_d[1] enet_tx_d[2] enet_tx_d[3] enet_tx_d[4] enet_tx_d[5] enet_tx_d[6] enet_tx_d[7] enet_tx_en enet_tx_er}] set_output_delay -clock { enet_gtx_clk } -max -add_delay 2.5 [get_ports {enet_tx_d[0] enet_tx_d[1] enet_tx_d[2] enet_tx_d[3] enet_tx_d[4] enet_tx_d[5] enet_tx_d[6] enet_tx_d[7] enet_tx_en enet_tx_er}] set_output_delay -clock { enet_tx_clk_25M } -min -add_delay -1.5 [get_ports {enet_tx_d[0] enet_tx_d[1] enet_tx_d[2] enet_tx_d[3] enet_tx_d[4] enet_tx_d[5] enet_tx_d[6] enet_tx_d[7] enet_tx_en enet_tx_er}] set_output_delay -clock { enet_tx_clk_25M } -max -add_delay 9.5 [get_ports {enet_tx_d[0] enet_tx_d[1] enet_tx_d[2] enet_tx_d[3] enet_tx_d[4] enet_tx_d[5] enet_tx_d[6] enet_tx_d[7] enet_tx_en enet_tx_er}] set_output_delay -clock { enet_tx_clk_2M5 } -min -add_delay -1.5 [get_ports {enet_tx_d[0] enet_tx_d[1] enet_tx_d[2] enet_tx_d[3] enet_tx_d[4] enet_tx_d[5] enet_tx_d[6] enet_tx_d[7] enet_tx_en enet_tx_er}] set_output_delay -clock { enet_tx_clk_2M5 } -max -add_delay 9.5 [get_ports {enet_tx_d[0] enet_tx_d[1] enet_tx_d[2] enet_tx_d[3] enet_tx_d[4] enet_tx_d[5] enet_tx_d[6] enet_tx_d[7] enet_tx_en enet_tx_er}] # **************************************************************# Set Clock Groups# ************************************************************** set_clock_groups -exclusive -group this_stratixIII_3sl150_dev_niosII_standard_sopc|the_altmemddr|altmemddr_controller_phy_inst|alt_mem_phy_inst|altmemddr_phy_alt_mem_phy_siii_inst|clk|half_rate.pll|altpll_component|auto_generated|pll1|clk[0] set_clock_groups -exclusive -group this_stratixIII_3sl150_dev_niosII_standard_sopc|the_sys_pll|the_pll|altpll_component|auto_generated|pll1|clk[0] set_clock_groups -exclusive -group clkin_50# set_clock_groups -exclusive -group clkin_125# set_clock_groups -exclusive -group tck set_clock_groups -exclusive -group [get_clocks {virtual_enet_rx_clk_125M enet_rx_clk_125M enet_gtx_clk}] -group [get_clocks {virtual_enet_rx_clk_25M enet_rx_clk_25M enet_tx_clk_25M}] -group [get_clocks {virtual_enet_rx_clk_2M5 enet_rx_clk_2M5 enet_tx_clk_2M5}] # **************************************************************# Set False Path# ************************************************************** set_false_path -from [get_clocks {this_stratixIII_3sl150_dev_niosII_standard_sopc|the_sys_pll|the_pll|altpll_component|auto_generated|pll1|clk[1]}] -to [get_clocks {enet_tx_clk_2M5}] set_false_path -from [get_clocks {enet_tx_clk_2M5}] -to [get_clocks {this_stratixIII_3sl150_dev_niosII_standard_sopc|the_sys_pll|the_pll|altpll_component|auto_generated|pll1|clk[1]}] set_false_path -from [get_clocks {this_stratixIII_3sl150_dev_niosII_standard_sopc|the_sys_pll|the_pll|altpll_component|auto_generated|pll1|clk[1]}] -to [get_clocks {enet_tx_clk_25M}] set_false_path -from [get_clocks {enet_tx_clk_25M}] -to [get_clocks {this_stratixIII_3sl150_dev_niosII_standard_sopc|the_sys_pll|the_pll|altpll_component|auto_generated|pll1|clk[1]}] set_false_path -from [get_clocks {virtual_enet_rx_clk_125M virtual_enet_rx_clk_25M virtual_enet_rx_clk_2M5}] -to [get_clocks {this_stratixIII_3sl150_dev_niosII_standard_sopc|the_sys_pll|the_pll|altpll_component|auto_generated|pll1|clk[1]}] set_false_path -from [get_clocks {this_stratixIII_3sl150_dev_niosII_standard_sopc|the_sys_pll|the_pll|altpll_component|auto_generated|pll1|clk[1]}] -to [get_clocks {enet_rx_clk_2M5 enet_rx_clk_25M enet_rx_clk_125M}] set_false_path -from [get_clocks {virtual_enet_rx_clk_25M}] -to [get_clocks {enet_tx_clk_25M}] set_false_path -from [get_clocks {virtual_enet_rx_clk_2M5}] -to [get_clocks {enet_tx_clk_2M5}] - Altera_Forum
Hi Leon, thanks for all.
So if i understanded well, with the code you provided i have no to manually reset the Phy (actually i connect the enet_resetn to a user button to reset Phy). Do you think this code is good for all boards that have Marvell phy? Bye - Altera_Forum
leonchang0000 (http://www.alteraforum.com/forum/member.php?u=6116), could you please specify the location to insert your patch in "altera_avalon_tse.c" file. Please, write strings after which I should insert your text.
If I am trying to use TSE in RGMII, do I need your patch, or it is useless? Thanks. - Altera_Forum
I understood about RGMII.. I have to change the code a little to use.
Yup.. I guess so..
Hey.. man, please read the thread carefully.. I already specified the line number to insert..
Good day, leonchang0000 (http://www.alteraforum.com/forum/member.php?u=6116). I have read the thread carefully and noticed about the line 1233, but my file is modified or it's just a newer version, so the line 1233 is just between
alt_32 alt_tse_mac_group_init() and alt_32 alt_tse_mac_get_phy() routines. I guess the code should be inserted into alt_32 alt_tse_mac_get_phy()? - Altera_Forum
Oki.. I see. no problems.. Herer i attach the source code here and please compare yourself.. it's pretty much based on 8.0.
Thanks a lot))
