18 years agoTriple speed ethernet and Marvell Phy on Stratix III
Hi.. Need help here!! I've been struggling for a couple weeks. I have a stratix III board with a on-board Marvell PHY. I just tried to make a triple speed ethernet working on MII mode (10/10...
17 years ago --- Quote Start --- Finally get it work with the support from FAE.. Just want to mention that design should be pretty straight-forward as specified on other threads. Two things are more critical. 1. timing constraints.. (it's less critical than 2.) --- Quote End --- Thanks Leon. Would you mind posting your timing constraints? I'm trying to use GMII interface (Marvell Phy, StratixIII devkit, tse IP), but I'm having a real hard time figuring out what the constraints need to be. -Brian
