18 years agoTriple speed ethernet and Marvell Phy on Stratix III
Hi.. Need help here!! I've been struggling for a couple weeks. I have a stratix III board with a on-board Marvell PHY. I just tried to make a triple speed ethernet working on MII mode (10/10...
17 years agoIIRC the Altera TSE mac doesn't work very well with RGMII at 10/100 speeds, so you should stick to MII. The constraints will need some adjustments as you are not in DDR anymore.
Did you try to connect SignalTap probes to the MII signals to check if anything is received on that side?
