18 years agoTriple speed ethernet and Marvell Phy on Stratix III
Hi.. Need help here!! I've been struggling for a couple weeks. I have a stratix III board with a on-board Marvell PHY. I just tried to make a triple speed ethernet working on MII mode (10/10...
18 years agoThanks for the reply.
I was connecting the ethernet cable into 10/100 router and i gounded set_1000 to make sure it's not running on Gigabit. Also i checked the LED indicator with the right ethernet mode indication. For the Signal Tap, I will try it right away. BTW, i happened to see some threads mentioning about timing constraints on TSE_MAC related signals. Do you think that's very likely apply in my case. I believe I didn't touch that at all..:(
