18 years agoTriple speed ethernet and Marvell Phy on Stratix III
Hi.. Need help here!! I've been struggling for a couple weeks. I have a stratix III board with a on-board Marvell PHY. I just tried to make a triple speed ethernet working on MII mode (10/10...
18 years agoFirst you need to check that the PHY didn't auto-negotiate a 1Gbs link. Because in that case if you try to use the MII interface it won't work.
Then you can add some Signal Tap probes to see what signals are coming from the PHY it should help you understand why the MAC doesn't process them.
