15 years agotransceiver design examples
Hi, I would like to modify a design example named aii_4ch_10b_2000Mbps (transceiver design example) in order to use CMU PLL0 for first two channels and CMU PLL1 for the other two. I have a c...
15 years agoI enabled the Custom PHY Transceiver doing as you suggested.
I didn't expect that a tool like Quartus could have such problems. Furthemore, with Qsys I cannot select CMU PLL0/1 for a given channel and it is not clear which relation there should be between input reference clock and Data Rate.
