Mingyuexin
7 years agoTiming violation when route emac from HPS to FPGA in quartus prime standard 18.1
Hi, I need to use route EMAC from HPS to FPGA because our system need 4 channels of ethernets, and one USB interface also. I refer to the examples from here https://rocketboards.org/foswiki/Projec...
KennyT_altera
7 years agoI see your report. This is a small delay happened from register to IO. Now u can try tune the d5 of d4 delay to close the remaining timing. D5 or d4 delay is shown in the IO, try to search it in the chip planner -> look into the specific IO -> resource property -> in the resource property editor -> right click on the triangle sign and see if you can modify the timing. Or you can just play around the value in the assignment editor.
