Timing violation when route emac from HPS to FPGA in quartus prime standard 18.1
I removed pin assignment for gmii interfaces, the timing was not improved, I checked the pins were assigned by Quartus to a different locations.
I then assigned gmii interfaces to other locations, I got those timing violations:
Slow 1100 mV 85 C model
-0.024 ns setup
-0.014 ns hold
Slow 1100 mV 0 C model
-0.062 ns setup
-0.057 ns hold
Looks like the timing improved a little bit after I change the pin location manually.
Well, since there are setup timing violation for all the tx pins, and hold timing violation for part of tx pins, I do not know where the over constraint should be set. Because the same path (e.g. from clock_ena to tx_d) is too long for setup analysis, but short for hold analysis.
I'm trying seed sweep (20 seeds), I will update the result when it's done.
Best wishes
Jasmine
Seed sweep does not help at all, all 20 seeds failed.
