Mingyuexin
7 years agoTiming violation when route emac from HPS to FPGA in quartus prime standard 18.1
Hi, I need to use route EMAC from HPS to FPGA because our system need 4 channels of ethernets, and one USB interface also. I refer to the examples from here https://rocketboards.org/foswiki/Projec...
KennyT_altera
7 years agoI look into the design, whenever they are two different clock domain. Timing will be different.
Since the violation is not much on those path, what I suggest you try different seeds to see if it can close the timing. As the timing had been close in Q14.0 before. https://fpgawiki.intel.com/uploads/e/e6/FittingAlgorithms_and_SeedSweeps.pdf
Mingyuexin
7 years agoThank you very much for the advice. It seems I have to do seed sweep manually, i.e. set different see value and see which one can close the timing. I have tried several seeds, I have not found any see which can close the timing yet.
Is there any trick to find the right seed faster? For example, do seed sweep automatically?
