fengxin
1 year agoThere is a problem with the flash curing.
Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the po...
FvM
1 year agoHi,
I'd expect you are trying to program flash through JTAG indirect mode with .jic file generated in programming file converter. Direct AS programming would require a second programming header which you don't have on your board, I guess. Silicon ID check might need to be disabled if .jic isn't setup for your Winbond flash.
