The target hardware identity couldn't be verified.
Dear Balerion,
I have tried to build the .hex file by using the below link.
But i'm unable to build,due to issue in OUTPUT Directory and make file,I have attache the error image for your reference.Could you help me in this.
Thanks ,
Gokulraj
- Balerion2 years ago
Hi Gokulraj,
I have tried with prebuild files. Can you also try with that from Index of /2024.04/gsrd/agilex7_dk_si_agf014ea_gsrd/ (rocketboards.org)
Balerion
- Gokulraj2 years ago
Dear Balerion,
While merging the .sof and .hex(u-boot-spl-dtb) file Quartus prime throw error as size of file exceeds memory capacity and i'm using .sof(Agilex_SOM.sof) file given by Terasic. Also i tried of configuring FPGA by using quartus_pgm command in terminal but this one also throw error as device agfb014r24b2e2v is not supported.
I have attached the error image.Do you face any of this errors.which part i'm missing,could you guide me.
Gokulraj
