the question about Whether the pin polarities of the FPGA are interchangeable PN
- 2 years ago
Hi gongmh,
There is an option RX Polarity Inversion in the Transceiver PHY IP which can invert the data input in the instance generated by this IP. You should enable the polinv port at the same time. And the polinv port will have bit width equal to number of channels used. It is used to invert P and N of data lines, but not clock.
Please refer to :https://www.intel.com/content/www/us/en/docs/programmable/683617/21-1/rx-polarity-inversion.html
Ethan
Hi gongmh,
Ethan
