15 years agoThe .flash file doesn't work in Arria IIGX development Kit
I have a problem when I used "sof2flash" to convert "factory_recovery\build_factory_source\bts_config.sof" to bts_config.flash.when used Quartus ii and Nios II EDS 9.0SP2,the problem is "The release...
15 years agoHi,
I managed to create .flash file and burn the flash with new image successfully for once. After that, I repeat the process but the FPGA can't run. It is configured successfully though, but all the logic just can't run? Quite confused, same sof file I've used to configure by JTAG, works perfectly.
