15 years agoThe .flash file doesn't work in Arria IIGX development Kit
I have a problem when I used "sof2flash" to convert "factory_recovery\build_factory_source\bts_config.sof" to bts_config.flash.when used Quartus ii and Nios II EDS 9.0SP2,the problem is "The release...
15 years agonot using the mentioned flags will cause the FPGA to fail configuration. take a look at the following solution:
http://www.altera.com/support/kdb/solutions/rd01152010_225.html
