16 years agoTHDB_ADA daughter board
Hi I am working with the THDB_ADA daughter board connected to the DE2 board. as i know, the input voltage range to the A/D is 2V p-t-p. when i'm supplying siganl vary between 0v and 2v, i'...
16 years ago --- Quote Start --- 5 or 10 MHz should perfectly work. The nominal input range would be actually 2 Vpp at the input connector, respectively about 10 dBm. You should use an oscilloscope to check the real input voltage, both at the input connector and the ADC inputs. P.S.: The signal generator must be able to drive 50 ohm, of course. --- Quote End --- Would you please send me the QUARTUS project to test ADC and DAC of thdb_ada daughter board with Cyclone III starter kit? Thanx
