16 years agoTerasic THDB_ADA question
Hi~~I have some questions about THDB_ADA 1) what's the ADC output data format? i found the AD9248's datasheet. there were two data output format, offset binary and two's complement...
16 years ago1. It's a hardware pin-strap option, as you can see in the datasheet. If I understand right, it's set to offset binary.
2. Incorrect connected LA probe or a hardware fault.
