3LionsCT
11 months agoTerasic Atum A3 Nano
Hi, I am working through the getting started manual for this board which is generally pretty good. However there are no examples of how to use the SDRAM or the Ethernet PHY on this board. It is not ...
FvM
11 months agoHi,
as you already found out, there's SRAM_RTL_test project on the support CD. Unfortunately single rate DRAM is no longer supported in Platform Designer, see Replacement for SDRAM controller after V16.1? | Altera Community
Regarding Ethernet connectivity, I presume standard TSE IP in RGMII mode will support the PHY.
- 3LionsCT11 months ago
Hi Frank,
Thanks for taking the time to answer my question
Do you know if there are header files for the TSE that I can use in a bare metal Ashling RiskFree project?
