17 years agoTerasic ADA Daughter Card
Hi
I am interested in Terasic ADA Daughter Card for DE1 Development Board (see link below) http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=39&no=278 I have asked about proforma invoice but they didn't responde and i don;t know why. :confused: At this moment card is out of stock. Do you know where else I can buy these card? Best regards25 Replies
I am interested in using the ADA board to generate DC voltages from 0 to 3.3 Volts. I realize that I will need to remove the transformer to have DC operation. Additionally, I would likely need to do something so that the circuit can provide the relatively high voltage. I believe that the DAC chip on the board is limited to around 1.2 Volts. Can anybody suggest a simple way to achieve the high voltages that I need? Thanks, Hooter - Altera_Forum
Can someone explain why there are two transformers in series on each ADC input? I understand that one is needed for level shifting, but why two?
Thanks - Altera_Forum
Obviously, they are intended to improve common mode rejection a higher frequencies.
Yes, that makes sense, thanks. I'm not sure I can agree that it is obvious :).
Agreed, but I think, it's the only plausible explanation. As the possibly more important question, I'm also not sure if it's necessary.
