17 years agoTerasic ADA Daughter Card
Hi I am interested in Terasic ADA Daughter Card for DE1 Development Board (see link below) http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=39&no=278 I have ask...
17 years agoOk, I understand the DAC end. Thanks
As for the ADC end, I think I have to try to do it. So where on the board is the best place to put in the signal? At R4 (for ch. A)?? I am assuming that the signal should be at Vin+. Is this correct? And you say that this signal need to have a 1.5V bias?? I think it should be possible to use an op amp but I it is also quite simple for me to add a 1.5V DC bias to my signal. Do you think this would work?? Have I misunderstood? Thanks again for your invaluable help.
