17 years agoTerasic ADA Daughter Card
Hi I am interested in Terasic ADA Daughter Card for DE1 Development Board (see link below) http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=39&no=278 I have ask...
17 years agoThanks,
I have thougth about my requirement and concluded that without beng able to use single ended operation/DC-coupling (Are they the same thing) then I cannot use it for my application. Hence, I would be grateful if you can help me out with the following questions: 1. From the schematic it is not clear to me where to install the jumper and , is it possible for you to provide more details on this?? IT is possible I can live live with the DAC part being AC coupled but the DAC part really has to be. 2. Is there any other AD/DA board that is compatible with the Cyclone II starter kit and allows DC-coupled inputs? 3. Is it possible combine the AD8132 amplifier that you mentioned with the Terasic ADA board? Thanks again Ben
