System hangs while testing Intel FPGA P-Tile Avalon Memory Mapped (Avalon-MM) IP for PCI Express Design Example User Guide example design
Is the links test 100 read & write passed? Could you please reduce the number of descriptors per DMA, or number of Dwords per descriptor to see if this make any difference?
Regards -SK
Intel FPGA PCIe Link Test
Version 2.0
0: Automatically select a device
1: Manually select a device
> 0
Opened a handle to BAR 0 of a device with BDF 0x100
0: Link test - 100 writes and reads
1: Write memory space
2: Read memory space
3: Write configuration space
4: Read configuration space
5: Change BAR for PIO
6: Change device
7: Enable SRIOV
8: Do a link test for every enabled virtual function
belonging to the current device
9: Perform DMA
10: Quit program
> 5
Changing BAR...
Enter BAR number (-1 for none):
> 2
Successfully changed BAR!
6: Change device
7: Enable SRIOV
9: Perform DMA
10: Quit program
> 2
Enter address to read, in hex:
> 0x4
Reading from BDF 0x100 BAR 0x2 offset 0x4..
Read 0
6: Change device
7: Enable SRIOV
9: Perform DMA
10: Quit program
> 1
Enter address to write, in hex:
> 0x4
Enter 32-bit data to write, in hex:
> 0xaabb
Writing 0xaabb at BDF 0x100 BAR 0x2 offset 0x4..
Wrote successfully!
6: Change device
7: Enable SRIOV
9: Perform DMA
10: Quit program
> 2
> 0x4
Read 0xffffffff
6: Change device
7: Enable SRIOV
9: Perform DMA
10: Quit program
> 10
AFTER REBOOT
vvdn@vvdn-hp:~$ sudo md.l f0210004
f0210004: 0000aabb 00000000 00000000 00000000 ................
f0210014: 00000000 00000000 00000000 00000000 ................
f0210024: 00000000 00000000 00000000 00000000 ................
f0210034: 00000000 00000000 00000000 00000000 ................
f0210044: 00000000 00000000 00000000 00000000 ................
f0210054: 00000000 00000000 00000000 00000000 ................
f0210064: 00000000 00000000 00000000 00000000 ................
f0210074: 00000000 00000000 00000000 00000000 ................
f0210084: 00000000 00000000 00000000 00000000 ................
f0210094: 00000000 00000000 00000000 00000000 ................
f02100a4: 00000000 00000000 00000000 00000000 ................
f02100b4: 00000000 00000000 00000000 00000000 ................
f02100c4: 00000000 00000000 00000000 00000000 ................
f02100d4: 00000000 00000000 00000000 00000000 ................
f02100e4: 00000000 00000000 00000000 00000000 ................
f02100f4: 00000000 00000000 00000000 00000000 ................
