System-Console JRE Error (18.0+). Happens on CLI but not on GUI.
2 bugs to report:
1) The same exact command ran in the system-console GUI works fine. However, adding the "--cli" flag generates the following error. Please help.
The TCL script has a single line:
puts "Wait for clients" vwait forever
Error generated in CLI when pressing the Enter key (in GUI everything works fine):
>> system-console.exe --debug --rc_script=intel_test2.txt --cli [...] % Accept sock2092 from 127.0.0.1 port 57221 Wait for clients # # A fatal error has been detected by the Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0000000057fdb8c3, pid=24452, tid=0x000000000000715c # # JRE version: OpenJDK Runtime Environment (8.0_322-b06) (build 1.8.0_322-b06) # Java VM: OpenJDK 64-Bit Server VM (25.322-b06 mixed mode windows-amd64 compressed oops) # Problematic frame: # V [jvm.dll+0x13b8c3] # # Failed to write core dump. Minidumps are not enabled by default on client versions of Windows # # An error report file with more information is saved as: #C:\intelFPGA_pro\quartus_systemconsole_22_2\qprogrammer\syscon\bin\hs_err_pid24452.log # # If you would like to submit a bug report, please visit: # https://github.com/adoptium/adoptium-support/issues
2) Attempt to pass a command through a catch/eval statement results in different status
I have included the test files I used. To reproduce, you will need 2 terminals.
Terminal 1:
C:\intelFPGA_pro\quartus_systemconsole_22_2\qprogrammer\syscon\bin>system-console.exe --debug --cli --rc_script=intel_test.txt
Terminal 2, after terminal 1 is done (~5-10s):
telnet 127.0.0.1 2540 get_service_types
In CLI, I receive an error message:
Executing client(sock2304)'s command: "get_service_types" Sep 29, 2022 12:03:22 PM com.altera.systemconsole.scripting.TCLCommand execute2 SEVERE: get_service_types: null [1]-> get_service_types: null CLIENT (sock2304): get_service_types SERVER (sock2304): Invalid command from the client ErrorMsg : get_service_types: null ErrorCode: NONE ErrorInfo: get_service_types: null while executing "get_service_types" ("eval" body line 1) invoked from within "eval $cmd"
While in GUI, everything works fine:
Executing client(sock2960)'s command: "get_service_types" [0]-> alt_xcvr_custom alt_xcvr_reconfig_aeq alt_xcvr_reconfig_dfe alt_xcvr_reconfig_eye_viewer alt_xcvr_reconfig_mifwriter bytestream dashboard data_pattern_checker data_pattern_generator design device etile executor hard_prbs_checker hard_prbs_generator io_bus issp jtag_debug loopback marker master module monitor packet plugin processor slave sld system toolkit trace trace_db transceiver_channel_rx transceiver_channel_tx transceiver_debug_link transceiver_reconfig_analog
Thank you
- RichardT_altera
You may checkout this webpage on Debugging with System Console Over TCP/IP.
You may checkout this rocketboard.
https://www.rocketboards.org/foswiki/Projects/RemoteSystemDebug
Richard Tan
- RichardT_altera
May I know does the information provided helps?
Richard Tan
- RichardT_altera
Any update on this? Do you need further help?
Richard Tan
- RichardT_altera
As we do not receive any response from you on the previous question/reply/answer that we have provided. I now transition this thread to community support. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you.
Richard Tan
- covfefe
@RichardTanSY_Altera , were you able to reproduce the issue?
Yes, I do need further help and would like this bug to be fixed, or a workaround to be provided.
The website provided, https://supporttickets.intel.com does not work. It redirects to the main support website, with no records of any tickets.
https://www.intel.com/content/www/us/en/support.html?random=-801661055
