System-Console I2C - master service cannot be found - Arria V
I want to talk to I2c peripheral devices (Si5338) on the Arria V dev kit.
I believe to do this with system-console, I need to open a master service with the Max V processor, then use the i2c protocol to access Si5338 (offset 0x70).
However, I seem to be unable to reach the Max V. Could someone help me understand what to do?
% get_service_paths {master} {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master} {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(70:34 v3 #0)/nios2_0} % claim_service master {/devices/5M(1270ZF324|2210Z)|EPM2210@2#USB-1} m error: Could not claim service at /devices/5M(1270ZF324|2210Z)|EPM2210@2#USB-1: The master service cannot be found at /devices/5M(1270ZF324|2210Z)|EPM2210@2#USB-1 while executing "claim_service {master} {/devices/5M(1270ZF324|2210Z)|EPM2210@2#USB-1} {m}" while executing "claim_service master {/devices/5M(1270ZF324|2210Z)|EPM2210@2#USB-1} m"
thank you
PS: I am able to talk to the Arria V device without issues (/devices/5AGT), it is the Max V that I have problems with (/devices/5M)
- RichardT_altera
1. Try to create a Tcl variable, lets say in this case, m_path
% set m_path [get_service_paths master]
2. Claim the master service to allow exclusive access to the master device:
% set c_master [claim_service master $m_path ""]
With the service claimed as the c_master variable, we can now use c_master to read and write any agent that's connected to the componenet.
3. Now try to perform read from and write to a component.
a. Type master_read_memory $c_master 0 32
b. Type master_write_memory $c_master 0 {0 1 2 3 4 5 6 7 8 9 10}
c. Type master_read_memory $c_master 0 32
Let me know if it helps.
Richard Tan
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey.
- covfefe
@RichardTanSY_Altera , I think my question was misinterpreted. I can talk to the Arria V no problem via master_read/write (device 5AGT).
Where I have issues is talking to the Max V on board (device 5M). I want to talk to the Si5338 (I2c), which I believe is through the Max V.
I am unable to find a master link to the Max V. How to do so?
- RichardT_altera
From your message provided:
while executing
while executing
The master paths only list out:
- {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(110:132 v1 #0)/phy_0/master}
- {/devices/5AGT(FD3H3|MD3G3)|5AGXBB3D4|..@1#USB-1/(link)/JTAG/(70:34 v3 #0)/nios2_0}
How do you connect to a master {/devices/5M(1270ZF324|2210Z)|EPM2210@2#USB-1} when it is not there in the first place?
Could you check that you are using the MAX V device in your project and run compilation prior system console?
Richard Tan
- covfefe
It is not part of the design, no. I didn't believe it had to?
I want to program the Si5338 and change the clock frequency, like the Intel Board Test System (BTS) does.
My understanding is the BTS is using the Max V to access the Si5338 via I2C protocol. Is this not correct? How does the BTS access the Si5338?
- RichardT_altera
The System console is a tool to access the Platform Designer system integration tool to perform low-level hardware debugging of your design, as well as identify a module by its path, and open and close a connection to a Platform Designer module.
Thus, it will depend on the PD system design that you used to program (.sof) the board.
I am not familiar with BTS but I think this is how you change the clock frequency in BTS?
https://www.intel.com/programmable/technical-pdfs/683460.pdf#page=33
Richard Tan
- RichardT_altera
Do you have further question?
Richard Tan
- RichardT_altera
Is there any update or follow-up questions from your side?
Richard Tan
- RichardT_altera
Thank you.
Richard Tan
