15 years agoStream data from CIII kit using UDP over 1000 Ethernet
I have a CIII kit (EP3C120F780). My ultimate goal is to use my CIII kit to connect an ADC board to my laptop. I want to stream data from my ADC board through the HSMC header and out to my laptop over...
15 years agoYou can use the Altera triple speed ethernet MAC and feed it with the UDP packets that you build with some custom hardware. Have a look at the nios ii udp offload example (http://www.alterawiki.com/wiki/nios_ii_udp_offload_example).
As an alternative you could try a software solution with a Nios CPU and a UDP/IP stack but I don't think it would manage to reach 112MBps, or at least not easily.
