16 years agoStratixIII kit: store FPGA config + NIOS.elf using the NIOS-IDE flash programmer tool
Dear Madam/Sir,
I have designed boards based on CycloneII FPGAs for which, having implemented a NIOS-II in the FPGA, I found very convenient to store FPGA .sof configuration file + NIOS hex code into the serial conf device (EPCS64) using the NIOS-IDE flash programmer. I have purchased a stratix III dev board on which a MAXII device is instead acting as a configuration controller and I am disappointed at seeing that what was so straightforward before it is now so obscure. I have been struggling quite some time but I couldn't find a clear explanation about storing the .sof and the .hex in the flash so that the MAX-II could fetch the proper information from it; having the code for the MAX-II could help some. Could You please tell me how to use the NIOS-IDE flash programmer to store both configuration, NIOS executable and the bootloader in the flash device? Why does ALTERA put a black box such as the configuration controller on a development kit which should serve as a tool to learn new tecniques?No RepliesBe the first to reply
