13 years agoStratix V GX Development Card: Board Test System cannot detect USB Blaster
We have a Stratix V development card (5SGXEA7K2F40C2N) and cannot get the development kit GUI (Board Test System) to detect the USB Blaster. The USB blaster interface is recognized through Quartus (...
13 years agoHi,
I've got the same issue with the Stratix V DSP Development Kit: USB Blaster is working correctly using the Quartus Programmger. But the "Board Test System" just shows the following error message:Connecting to the target...
java.lang.Exception: Could not find device 0x029070DD
This problem could be caused by an older version of Quartus. Please ensure Quartus 9.0 is installed.
Starting the BTS using the command line (c:\programme\altera\quartus12.1\kits\stratixvgs_5sgsmd5kf40_dsp\examples\board_test_system>jre1.6.0_07\bin\java.exe -djava.library.path=lib -jar bts.jar) gives the following output: 19.02.2013 16:25:12 com.altera.systemconsole.internal.core.SystemConsole logSevere
SCHWERWIEGEND: Unable to find AJIDevice constructor
java.lang.RuntimeException: Unable to find AJIDevice constructor
at com.altera.systemconsole.internal.plugin.jtag.aji.AJICable.getDevices0(Native Method)
at com.altera.systemconsole.internal.plugin.jtag.aji.AJIChannel.scanDevices(AJIChannel.java:79)
at com.altera.systemconsole.internal.plugin.jtag.aji.AJICable.queryDevices(AJICable.java:182)
at com.altera.systemconsole.internal.plugin.jtag.JtagConnectionProvider.queryCableDevices(JtagConnectionProvider
.java:228)
at com.altera.systemconsole.internal.plugin.jtag.JtagConnectionProvider.doRescan(JtagConnectionProvider.java:194
at com.altera.systemconsole.internal.plugin.jtag.JtagConnectionProvider.access$000(JtagConnectionProvider.java:4
0)
at com.altera.systemconsole.internal.plugin.jtag.JtagConnectionProvider$2$1.run(JtagConnectionProvider.java:119)
19.02.2013 16:25:12 com.altera.systemconsole.internal.core.SystemConsole logInfo
INFO: Finished discovering JTAG connections Running "jtagconfig --debug" yields the following output: 1) USB-BlasterII
029070DD 5SGSMD5H(1|2|3)/5SGSMD5K1/.. (IR=10)
020A40DD 5M(1270ZF324|2210Z)/EPM2210 (IR=10)
Node 00406E7B (110:8)# 123
Node 00406E00 (110:8)# 0
Node 00406E01 (110:8)# 1
Captured DR after reset = (029070DD020A40DD)
Captured IR after reset = (55555)
Captured Bypass chain = (0) So the device with id "0x029070DD" is actually accesible through the jtag chain.
