13 years agoStratix V GX Development Card: Board Test System cannot detect USB Blaster
We have a Stratix V development card (5SGXEA7K2F40C2N) and cannot get the development kit GUI (Board Test System) to detect the USB Blaster. The USB blaster interface is recognized through Quartus (...
13 years agoHi,
I am using the same device and I am having the same error message when using Board Test System Connecting to the target... java.lang.Exception: Could not find device 0x029030DD This problem could be caused by an older version of Quartus. Please ensure Quartus 9.0 is installed. However, I have been able of running the .sof files for BTS included in the folder "examples, board_test_system ,bts_xcvr2_xfp_sfp_sma" by running Quartus II, Programmer and loading the .sof file in the FPGA that way. The drawback is that you cannot see what is happening, you just see the eye diagram running at 12.5 GBps. The file I am not able to find is the one needed to tun the Board Update Portal. I was trying to load into the FPGA the Transceiver Signal Integrity Demostration that is supposed to be in the "demo" folder of StratixVGX Kit, but that folder is empty, it doesn't contain any .flash file. does any of you have the signal_integrity_demo1.flash file??? Thanks. Lucia.
