15 years agoStratix IV Transceiver SI Dev Kit: The GUI could not communicate with the board...
After spending 1.5 months going back and forth with Altera support in Penang, I figured I'd try here. My original support request was as follows: --- Quote Start --- We have been un...
15 years agoThe solution that I found is that:
1. You first install the QII 11.0 2. Then you install the QII 9.1 on the same machine 3. You run the Programmer (either from 9.1 or 11) to download the file 4. The GUI for the SI board is working fine using the 9.1 drivers. 5. You run the QII 11 to load the transceiver toolkit
