15 years agoStratix IV Transceiver SI Dev Kit: The GUI could not communicate with the board...
After spending 1.5 months going back and forth with Altera support in Penang, I figured I'd try here. My original support request was as follows: --- Quote Start --- We have been un...
15 years agoAs far as I know, the SI GUI only requires Quartus Programmer libraries.
It means, the web edition should work. Even stand-alone-programmer will work. I would say, double check that you do not have any other blasters connected to the PC. This GUI can only recognize 1 blaster at a time, so if you have byte-blaster or something else in your PC, you need to disconnect and remove from the programmer list.
