15 years agoStratix IV Transceiver SI Dev Kit: The GUI could not communicate with the board...
After spending 1.5 months going back and forth with Altera support in Penang, I figured I'd try here. My original support request was as follows: --- Quote Start --- We have been un...
15 years agoHi,
After a very long exchange with support I finally received the following information: --- Quote Start --- FYI, I just got an information from our factory that it might be because the complete QII 91 is required..since there is some problem in the JTAG DLL that requires the entire QII91 to be installed. The way the GUI is packaged is that only the DLL’s related to programming is included. - Could you please confirm if complete Quartus II 9.1 (subscription edition) is installed too. If not, please try to install them and try re-running the GUI. --- Quote End --- After downloading and installing the subscription edition of Quartus II 9.1, I was then able to use the GUI. I haven't yet tested if the GUI actually works under Windows 7 (I suspect it does) however, I was able to run the GUI in a Windows XP Mode Virtual PC (after installing the kit software and subscription quartus II). You can download Quartus II here: https://www.altera.com/download/software/quartus-ii-se/9.1 (https://www.altera.com/download/software/quartus-ii-se/9.1) Information on setting up XP mode under Windows 7 can be found here: http://www.microsoft.com/windows/virtual-pc/download.aspx (http://www.microsoft.com/windows/virtual-pc/download.aspx) I haven't had a chance to experiment too much with the board since I got it running (as I've had to move onto other things). If you do happen to run it under Win 7 I'd be interested in finding out. Cheers.
