15 years agoStratix IV Transceiver SI Dev Kit: The GUI could not communicate with the board...
After spending 1.5 months going back and forth with Altera support in Penang, I figured I'd try here. My original support request was as follows: --- Quote Start --- We have been un...
15 years agoDo you have multiple blaster nodes?
I assume the GUI only accept 1 node, the embeded USB blaster on the board. If you have remote-jtag, delete it list. If you have byte-blaster, delete it from list. I assume it will run on xp-32 and 7-32, I do not have it in my hand, so I can not test it though. If you can post the error or detail, I might be able to help a bit more.
