Phil10's avatar
Phil10
2 years ago
Stratix III Early Power Estimator Problem
I'm using a Stratix III dev board and I was trying to use the EPE (Early Power Estimator) spreadsheet and none of the two versions seem to work, the 2010 Excel version seems to be a 97-2003 version instead of 2010 and both versions when opened and then the macros selected to be enabled seem to crash Excel and ultimately close Excel down.
Note I've tried using Excel 2016 and 2007.
Is there something that I'm doing wrong? ...or do the spreadsheets actually not work? ...is there a fix for this?
Phil
  • Farabi_Altera's avatar
    Farabi_Altera
    "We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
    Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
    We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
    Thank you for your understanding."
