Stratix 10 TX SI Development Kit: "PWR ERR" LED flashes intermittently and it is tricky to program it without errors in the transfer. Hardware problem?
Hi
Thanks for your update. Could you try on this? Perform the BTS test with Quartus v. 18.1.2.277 as recommended and set all DIP switch back to factory default state and try to recover the board.
You can download Quartus at https://fpgasoftware.intel.com/18.1/?edition=pro&platform=windows
- TJoha66 years ago
Hi, no success. All switches checked (we have not changed them anyway).
Tested with Q18.1.2.277 and BTS with two Linux and one Win7 computer. The USB-II communication is erradic, BTS does not work at all, the programmer can talk and identify the device, but not fully transfer a .sof file (error/crash after different % of uploads, trying many times, each time somewhat different but never 100 % and green).
The D5 PWR ERR is still flashing fast intermittently. (When I tested with some of the switches related to supply settings, it went to bright amber light, and back to flashing again when I set the switch back to the factory setting.)
To me it seems like a hardware problem with an on-board supply.
