Stratix 10 SOC Development Kit
- 1 year ago
Hi Fakhrul,
Thanks for the reply.
This issue is solved, and the solution is,
In the Stratix 10 SX soc development kit, if the 10th dip switch of SW1 is only turned on then was able to program the Stratix 10 SX FPGA, with the desired .sof
Kiran
Hi kiransr,
As mentioned by sstrell above, there shouldn't be an issue. This is typically caused by multiple devices with similar JTAG IDs in the JTAG chain, somehow it may leading the software to incorrectly identify the target device. This often occurs when using a development board with multiple FPGAs or other devices sharing the same JTAG interface. The software may need additional information to correctly distinguish between them.
Let me know if you need further assistance.
Fakhrul
- kiransr1 year ago
Hi Fakhrul,
Kiran
