kiransr
1 year agoStratix 10 SOC Development Kit
Hi, I am using the Stratix 10 SOC Development Kit and when programmer is opened in the Quartus and through auto detect I am not seeing the FPGA 1SX280HU2F50E1VGAS (as mentioned in the datasheet) wh...
- 1 year ago
Hi Fakhrul,
Thanks for the reply.
This issue is solved, and the solution is,
In the Stratix 10 SX soc development kit, if the 10th dip switch of SW1 is only turned on then was able to program the Stratix 10 SX FPGA, with the desired .sof
Kiran
sstrell
1 year agoYou can try just assigning your programming file (.sof) to the device shown. It will get the correct device info from the file. This shouldn't be an issue.
- kiransr1 year ago
Hi sstrell,
What am saying is auto detect shows a different device then the one mentioned in the datasheet, why is that so ?
Kit is stratix 10 soc development kit that is being used.
Kiran
