DZuck1
7 years agoStratix 10 HPS - Added EMAC does not show up in Linux
Hi, I am using a project based on the GHRD/GSRD for the Stratix 10. The reference design comes with 1 EMAC enabled in the HPS system and it is brought out to an external PHY. I am trying to add 2 m...
EBERLAZARE_I_Intel
7 years agoHi,
Based on my knowledge, when adding a new component affect the HPS (such as adding the extra EMACS), you will need to recompile everything, Platform Designer, Quartus etc.
Have you tried running the reference design for the first time to see if it is running successfully?
- EBERLAZARE_I_Intel7 years ago
My apology, by first time I mean without adding the extra EMACS, with everything default.
- DZuck17 years ago
Yes, the project works fine before I add the extra EMACs. Are there any changes to uboot/Linux that need to be made? Do the Device Tree Blobs (DTB) need to be modified? - EBERLAZARE_I_Intel7 years ago
Yes, since the changes are affecting the HPS, the preloader, uboot , dtb need to be recompile to take affect of the changes made.
May I know are the project files that you use already prebuild?
