n_nuti
3 years agoStratix 10 H-TILE Signal Integrity Kit - PCIE
Hello, My team and I are trying to use an FMC to PCIE adapter on an S10 h-tile signal integrity kit. In doing so, I need to use the following pins to connect to the H-TILE PCIE IP: I'm curren...
Wincent_Altera
3 years agoHi Nicholas.
- can I know which quartus version that you are using ? can you try the latest version of quartus and see if you are able to replicate the issue ?
- Do you try the resolution mentioned Error : Device has stopped receiving configuration data (intel.com) ?
- Is it workable ?
Wei Chuan
