n_nuti
3 years agoStratix 10 H-TILE Signal Integrity Kit - PCIE
Hello, My team and I are trying to use an FMC to PCIE adapter on an S10 h-tile signal integrity kit. In doing so, I need to use the following pins to connect to the H-TILE PCIE IP: I'm curren...
n_nuti
3 years agoUpdate:
- Specified voltages were measured to be within spec:
- S10_VCCH = 1.804V
- S10_VCCRL = 1.119V
- S10_VCCRR = 1.119V
- S10_VCCT = 1.119V
- I checked through all on-board switches to see if anything is out of the ordinary... nothing obvious
After checking through more of the schematics I couldn't find anything obvious...
I was actually able to program my S10 board with my PCIE IP project but only in a specific situation... The system is only able to be programmed if the BITEC DP FMC card that we have is connected to FMCA. If FMCA has the FMC to PCIE connector, we get the configuration error specified in the previous post.
I've been studying the BITEC DP FMC card and it doesn't have anything out of the ordinary except for:
- PRSNT_M2C_L (H2) connected to GND
- TDI (D30) is looped-back to TDO (D31)
I do not have schematics for the FMC to PCIE card at the current moment. Are there any specific FMC/PCIE HARD IP requirements for Stratix 10?
Thank you,
Nick
