Storing bitstream in Startix V GS SI eval kit and transmitting through the transmitter.
Hi Srikanth,
Thanks for your clarification that you will be using the transceiver TX to send serial data at 8G to 10G data rate. As I search through the web, there seems to be no specific simple example design on this. I have attached a Modelsim simulation example which was previously from wiki for your reference. To run the simulation, do the following:
1. Extract the ZIP
2. Change the working directory of Modelsim to the ZIP folder
3. Type "source simulation_setup.tcl"
4. Type "simulate" to start the compilation and simulation
Note that this example was targeted for Q15.0. You can try out to see if it still working on your side.
As I looked into the a.v file, it seems like it is connected to a constant pattern generator. You can replace this with your own pattern generator.
It is recommended for you to go through the following documentation for further details on the transceivers prior to performing testing:
1. Stratix V Device Handbook Volume 2: Transceivers - https://www.intel.com/content/dam/altera-www/global/en_US/pdfs/literature/hb/stratix-v/stx5_xcvr.pdf
2. V-Series Transceiver PHY IP Core User Guide - https://www.altera.com/content/dam/altera-www/global/en_US/pdfs/literature/ug/xcvr_user_guide.pdf
