16 years agoSSRAM (IS61LPS25636A)) on Cyclone III starter board
I am trying to read a bunch of data from SSRAM (IS61LPS25636A)) on Cyclone III, which is 256k*32 bit in size. However, from the board manual, there are 32 data bits, 21 address bit (should be 18 bits...
16 years agoI tried to use the following code to read a set of data from SSRAM, but found I can only get the very first data in address 18'b0; can not read others even I changes the address.
Can anybody help about this? Thanks. `timescale 1ns / 1ps module mem_read( ssram_clk, clk, reset_n, ssram_adsc_n, ssram_bw_n, ssram_bwe_n, ssram_ce_n, flash_ssram_a, flash_ssram_d, ssram_oe_n, test_led ); input ssram_clk; input clk; input reset_n; output wire ssram_adsc_n; output wire [3:0] ssram_bw_n; output wire ssram_bwe_n; output wire ssram_ce_n; output wire [19:2] flash_ssram_a; input [31: 0] flash_ssram_d; output reg ssram_oe_n; output wire [3:0] test_led; assign ssram_adsc_n=1'b1; assign ssram_bw_n=4'b1111; assign ssram_bwe_n=1'b1; assign ssram_ce_n=1'b0; // assign flash_ssram_a=counter1; // assign ssram_oe_n=1'b0; reg [1:0] counter; always@(posedge ssram_clk, posedge reset_n) begin if (reset_n) counter <=2'b00; else if (counter1==18'b111111111111111111) counter <=2'b00; else if (counter==2'b11) counter <=2'b01; else counter <= counter + 2'b1; end //counter reg [17:0] counter1; always@(posedge clk, posedge reset_n) begin if (reset_n) begin counter1 <= 18'b111111111111111111; end else if (counter1==18'b111111111111111111) counter1<=18'b000000000000000000; else begin counter1<=counter1+18'b1; end end assign test_led[0]=reset_n; assign flash_ssram_a =counter1; always @(negedge ssram_clk, posedge reset_n) begin if (reset_n) begin ssram_oe_n <=1'b1; end else if (counter1==18'b111111111111111111) begin ssram_oe_n <=1'b1; end else if (counter==2'b01||counter==2'b11) begin ssram_oe_n <= 1'b1; end else if (counter==2'b10) begin ssram_oe_n <= 1'b0; end else ; end endmodule
