17 years agoSRAM K1B3216B2E on Cyclone III Development Kit
dear sopc experts, has anyone used the 2 x 32mbit sram K1B3216B2E on altera cyclone III development kit or altera stratix III development kit? my problem: i instantiated a sopc with an tri...
16 years ago --- Quote Start --- Please use an and-logic and a latch for the wait-signal. Remember the lsb of the tristate address is not connected (tristate bus: 26 bit (25..0), sram and flash bus: 25 bit (24..0). Timing: Use a pll to generate the 100MHz clock for the avalon bus in SOPC-builder. Generate another 100MHz clock for the SRAM with a phase shift of -3,5ns The utram is optimised for 100MHz clock. See the documentation in the \ip\utram directory for other timings. see attachment for wait-logic and assigning the address-bus. --- Quote End --- thanks for your quick reply. thet example pass memory test as well but i still do not have working project. I tried to extract utram component and put it to my project but my nios can not run using that memory. Do you have idea what is wrong . Regards Marcin
