15 years agoSOPC with SDRAM Contoller
Hy everyone, I am new in building SOPC. Here is my objection : creating SOPC with SDRAM to write a simple Hello world on NIOS II by using DE0 development board. I got an error message from NI...
15 years ago --- Quote Start --- Do you mean that I cant separate the clock for CPU and the clock for SDRAM? --- Quote End --- You can use a separate clock for sdram with same or different frequency. I meant you however need a separate clock for driving the external sdram clock pin, because you must apply the phase shift. So, in a general case you have 3 clocks: - cpu_clk - sdram_clk, connected to sdram controller inside sopc builder - sdram_ext_clk, same freq as sdram_clk but -1.5ns phase shifted; this only connects outside to sdram clk pin. --- Quote Start --- I made a calculation based on the formula on the user guide, which lead to -1.46 ... and do you mean minus 1.5ns? --- Quote End --- Yes. Minus means a phase lead as I told you. So my -1.5 guess was good!
