15 years agoSOPC with SDRAM Contoller
Hy everyone, I am new in building SOPC. Here is my objection : creating SOPC with SDRAM to write a simple Hello world on NIOS II by using DE0 development board. I got an error message from NI...
15 years ago --- Quote Start --- seems like NIOS didn't take the new SOPC system that i've fixed. So i tried to create a new project file and input the new system once more. I got below error : verifying 01000000 ( 0%)
verify failed between address 0x1000000 and 0x100d96b
leaving target processor paused --- Quote End --- Something has changed but there's still something wrong if sdram base address is really 0x800000. Or is it actually 0x1000000? Do you mind posting the picture of your sopc? So I can see all bus connections and base address --- Quote Start --- Besides, I need to ask if i need to assign input/output pin for this SDRAM in this SOPC? --- Quote End --- Sure, you must assign sdram pins. But you must do it in Quartus project, not in sopc builder. If you are a beginner, remember the flow is as follows: - design the sopc system - when you generate it, sopc builder creates a black box block with contains the system and exposes the reuired i/o pins (i.e. clock, reset, sdram i/o, PIOs, ...) - add the sopc block in your Quartus project (as HDL or schematic) - you must connect the block pins to fpga device pins, adding glue logic if required - assign the used pins, based on how the actual fpga is connected to external devices (clock, sdram) on your board. - compile quartus project which creates the .sof configuration file - create the Nios bsp and application and associate it to your sopc system - load the fpga configuration - build and load the Nios application Regards
