16 years agoSOPC System Generation Error!
Hello, I recently started working with the Altera NiosII Development kit based on Cyclon II FPGA. When I try to open the standard reference design provided using the SOPC builder and generate ...
16 years agoHi!,
Here is the reply I got from Altera. I could solve this issue following the steps listed down. For error message "isa_europa.pm: calc_max_control_reg_sz(): No register size available for register cpuid", it is a running environment issue. If you have multi-version installation of Quartus II, when using v9.0, please make sure the following environment variables are set as follows (for example): QUARTUS_ROOTDIR = C:\ALTERA\90\quartus SOPC_KIT_NIOS2 = C:\ALTERA\90\nios2eds Please also delete environment variable SOPC_BUILDER_PATH (but you need to save the values for restoring when using versions other than v9.0). When using Quartus II/IP/Nios II EDS before v9.0 (such as v8.1), please recover the environment variable SOPC_BUILDER_PATH and set the value of the environment variables as follows (for example): QUARTUS_ROOTDIR = C:\ALTERA\81\quartus SOPC_KIT_NIOS2 = C:\ALTERA\81\nios2eds Then remove the following folders and restart Quartus II to try it again. c:\documents and settings\<user name>\.altera.quartus c:\documents and settings\<user name>\ipToolbench c:\documents and settings\<user name>\.sopc_builder. Best Regards
