15 years agoSOPC Building Error
Hy All , I am building a simple LED test pattern from "Board diagnostics" and selecting my own system (created my SOPC builder in Quartus II). After that I go to the "system library properties...
15 years agoThank you again Supal Shah:),
"Anyway,you can not run this code with on chip memory.And if u unchecked 'small C library' then u will not be able to use those functions." From above statements, it means that i have to run the functions off-chip memory(which can be larger)? Btw , I want to ask another newbie question about UART.I added UART function to my system and i got "rxd_to_the_uart" and "txd_from_the_uart" pins. My question is it necessary for those pins to be assigned to any of my DE0 board? Thank you, Yuyex:o
